Having problems with my system
9 Dec 2012
Leek
I recently brought a new case from overclockers and am swapping my system which I got from overclockers 2 years ago across to the new case, the only change I made to the original system was upgrading the graphics card from an MSI GTX 460 to a Gigabite HD 7950 a month ago and it all worked fine.
I swapped it over to the new case and set it up and it says no signal on my monitor.
I have tried:
Without any graphics card
With new graphics card
With old graphics card
With new and old case
Set it up without a case as a "barebones" set up
Used 3 different monitors and a TV
I am starting to think its my motherboard but just wanted to know what you think, any input would be appreciated as I have no idea what to do/try next.
Thanks.
Have you attempted to re-seat the motherboard? I had this a long time ago, the mobo was shorting on the case when screwed in, possibly too tight, or not positioned correctly.
Yeah tried it screwed in both cases, placed lightly screwed in the case and set up on my desk without a case
I have a Asus p8z68-v motherboard.
The basic barebones set up I did was like:
Motherboard with the "big power pin" connected to power supply
Graphics to motherboard with 2x PCI E to power supply
Hard drive conducted to motherboard and moles power supply
And HDMI cable to monitor
Have I missed something? I think I have but can't see what. Also not set up in case so no led or fans (apart from on the graphics card and CPU) or anything
Did you connect the 8 pin cpu power cable, usually at the top left of the board?
