Having problems with my VVTi engine
31 Dec 2003
Stoke on Trent
On my Gen 7 Toyota Celica.
There isn't an increase in acceleration in the higher revs range (bit like vtec in a Honda) like there was in my last Celica, anyone got any ideas please?
I have no engine management lights on. The only thing I can think of that I havn't tried is to clean the mass air flow sensor, but it sounds like a long shot to get it working.
thanks in advance if you can help.
Its a completely different car with a completely different engine, but I wasted a lot of time trying to sort out a similar problem with my car - tried out to be a blocked air filter. Check the basic things first :)
Could also be the MAF - run it with it disconnected and see if its better (although wait for someone more knowledgable than me on this particular engine to confirm!)
The lift should kick in at 6200rpm and only when the engine has reached normal operating temperature. From the wording of your post it has never done it? Are you sure you have a 190 and not a 140.
It definately should have a kick though, my old 140 did, and I know other people's Celica 140's have this kick
I dont think it should - the 140 is the economy variant of the engine. There is no performance kick as this is not what that engine is supposed to offer. Not all VVTi systems are equal.
VVTi compared to VVTi-L isnt it?
lol, i would begin to doubt myself now but a chap who works for toyota on the owners club agrees there's a difference in acceleration, albeit less so than in the vvtli
Only in the same way that Mk4 Golf GTI owners are convinced they have fast cars I should imagine :p
Indeed, theres no sharp increase on acceleration on the 140 its just the natural engine workings, the 190 though has the dual camshaft which is what most of us are thinking of:
Unique to the ZZ family, the 2ZZ-GE utilizes a dual camshaft profile system (the "L" in VVTL-i, known by enthusiasts as "lift") to produce the added power without an increase in displacement or forced induction .... This is similar in concept to Honda's i-VTEC, but the two systems are very different in design and execution.
The 140 uses the 1ZZ FED engine, 190 uses the 2ZZ GE engine.
How far did your old '140' rev up till?
Clean your MAF sensor, they get hella dirty and ruin everything! I cleaned mine and it felt like a different car.
Do not disconnect the MAF or you will get a light and a boggy car.
Nickg, thats a good website that, proves that perhaps I'm fantasising about my old car!! :confused:
Rackerz - I'm pretty sure I thought vvti made a difference to revving at about 6000 revs but not sure what it red lined at. I'll get some of this MAF sensor cleaner i've seen on the auction site and spray some on, it can't hurt I suppose. Feel a bit glum tbh!
ya im not saying that if you are just cruising and then BOOT IT that you wont get an instant kick up the rear. the engine has a good amount of torque (similar to the 2zz) but more easily accessable...but when u floor it low in the rev range it should accelerate fairly hard - but smoothly right to the end (and drop off slightly near the rev limit)...
wheras the 2zz builds slowly...then spikes and flattens out.
VVTi is working constantly to ensure that the valves are at the optimal timing across the rev range for max fuel/power efficiency.
