having to reset wireless router every now and then
12 Mar 2006
N.E England
for some reason since i upgraded my router wireless router (Netgear WGT624) firmware every now and then the wireless signal will just be cut out, i loose total connection but the lights are still all acting normal etc, once i turn off the router at the wall and back on again it works fine, sometimes it will do it non stop other times its fine. Prehaps i should roll back to the earlier firmware i had this problem with a linksys wireless router before i had this one and i had upgraded the firmware on that aswell, very weird. Can anyone help? i also have ntl broadband
