having trouble on my build
19 Aug 2005
oxfordshire
Power issues dont think its the power supply as i have tried another and it does the same thing, i got down to the fault, every time i plug the 4 pin power plug into my gigabyte ga 965p ds3 board it start a loop reset its self as if there is not enough power, when i unconnect it, i can get to power on, but not boot up on screen which ever card i try , old pci card and pci express,
i was thinking chip or board, what would make this happen
chip is s e660
power suppies tried are jan tech 750 and zalman 650 got ballistx trance 8500 in there
any help would be great:eek:
Right, so when you plug in the ATX 4pin plug the motherboard boots or do you press the power on button?? Is that right? It is possible to make it a little clearer as I can't make out what your doing to help fault find.
What RAM have you got in there?
right when atx 4 pin is plugged into the board and i press the pwer button it powers up then dies and repeates it self, when i unconnect it i get it power up but not boot
ballistx tracer 2gb
