Oh boy! I hear you say,
Speedstep is great
but I notice the difference in general system response when its enabled and the cpu isn't under load enough to bring the cpu to full speed, when browsing and sys fplder/file searches for example..
Has anyone came accross and application that is small and not a resource hog that will put the system in full speed and the program must be capable of being enabled to run in a very low priority cpu mode.
So basically with this app your would be able to keep your cpu running a full speed as and when you want. I will be looking for any small app that is capable of this feat maybe you have already something that can do this?
Don't suggest turning off speedstep as this defeats having the cake and eating it at the same time
Speedstep is great
but I notice the difference in general system response when its enabled and the cpu isn't under load enough to bring the cpu to full speed, when browsing and sys fplder/file searches for example..Has anyone came accross and application that is small and not a resource hog that will put the system in full speed and the program must be capable of being enabled to run in a very low priority cpu mode.
