Hazro H27WC: DP to DVI not working
18 Jul 2020
I've found this old monitor on Gumtree for 50£. The pc I have (HP Z400 has an Nvidia Quadro nvs 295).
The Quadro has Displayport connections, the only way to connect them to the monitor it's a DP to DVI adapter
I've tried two different adaptors but screen remains black and blue light keeps blinking.
Any suggestions? Thanks
Got the same monitor myself.....bought various adapters for under £20 non of them worked.
Startec do one but its well over £100
There are some on auction site that i was told will work for £60 but i decided to leave it and use another monitor for gaming instead...not sure if i am allowed to link to it even though ocuk dont sell the ones that work...
its a mini dp one so you also need another adapter for that too :)
you need to enable your "trust" account please.....bottom left next to "multi" and "quote" on any of your posts
