Hazro HZ26Wi problem
19 Aug 2008
So, I went downstairs to get a drink. When I came back up, the monitor was off.
It keeps repeatedly trying to turn its self back on. The backlight flickers maybe 3-4 times, then the green light above the "on" button goes out again. A few seconds pass and it will do the same thing. In a constant loop.
I've tried leaving it off for awhile and then turning it back on. Same problem. I've tried taking out all of the inputs, in the hope that maybe it would load and I could get to some menu. But, nothing is happening.
I can't even turn it off without unplugging it. It's in a constant loop of failure.
Has this problem ever happened before? Is there a way to fix it?
If not, I suppose I'll have to contact Hazro to fix it =(. Bah, I've got work to do too... =(
