Hi all
Unsure if I should have put this in an existing Hazro thread! they all seem quiet at the moment!
I'm in need of a new monitor to replace my old SM 226BW.
Now I'v been looking into the Hazro HZ27WA for a few days now and was just about the pop in and get one direct from OC as I only live around the corner
As a final check, I searched through the forum and read all the posts on the Hazro's including the problems reported!
Just goes to show how useful this forum was and the feedback given, I had no idea about the issue's
Now am I correct in thinking? "IF" you get a good one with no dead pixels or dust then its a cracking monitor for the money compared to the ACD price or equivelent monitors?
Pro's from my point of view!
- 27" IPS with the same LG panel that's in the ACD for nearly £400 cheaper?
- Value for money, carn't really stretch to the dell u2711 and the cheap 27" on OC don't seem great?
- big improvement over my 22" 226BW
Con's
- Potential dust behind glass panel and possible dead pixels!
The only good point is I'm only around the corner, If I get a poor example I can just take it straight back to OC.
Plus I could ask for it to be checked first for high dust levels! they may not want to open a box up but it may save another one coming back?
a tiny bit of dust I could live with, and maybe the odd pixel as I'm not a pro user/gamer. From what I can gather you can only notice faults if you search for them/test
Possible later batches have these issue's resolved as not all seem to have a problem??
Any advice appreciated
Con's
