hazro hz27wc problems
25 Jun 2011
schweden
I would be satisfied with this large and colorful monitor if there was not
for some problems i have with it.
firstly there seems to be a fair bit of
backlight bleeding in the upper right "corner" of the screen as seen here
And here where i apply some light pressure to the bezel@the bleed spot it changes form
and this is while playing a movie
also there seems to be some problems with green snow/noise/distortion in
the image under certain circumstances as seen here
I guess the blacklight bleeding is something i have to live with due to
hazros "relaxed" warranty but the pixel distortion is something i dont
really think should be there? (sometimes its even worse than in the
video) at first i thought it was my overclocked and abused old 5850 that
was causing the problem, but all the videos posted above is shot when the
screen is running from my htpcs ati hd4350 and using the supplied dvi-d
dual link cable from hazro.
tldr: would a new and more higher quality dvi cable solve this pixel
problem or would i be forced to try and rma the monitor(this would not be
cheap for me as i live outside of the uk)
Regards.
i have tested the monitor with a new and expensive cable but the problem is still there... guess i will have to try and return it :(
So now after my small vacation i have sent an rma request for the monitor to hazro(seems that was the way i should do it according to OCUK). But it has been 1 week since i contacted them and still no reply :( would be great to get this monitor fixed and would be even cooler if hazro was not so damn slow with their replys.
In fairness I could hardly notice the backlight bleed on your monitor until you went for the close up and pushed the bezel.
Although that's probablu due to my crappy monitor I'm using now.
