Hello,
I hope somebody might be able to help a long time lurker. Unfortunately my HZ30w has decided to die, the led on the front flashes but the screen doesn't turn on. I have tried replacing the power supply to no avail, so thought the next logical step would be to have a look inside.
Maybe I'm being thick, but there doesn't seem to be any way to get the stand off the back. There are 2 philips screws located right at the base of the stand that are so recessed even an offset screwdriver is no good. I can't seem to get at them at all.
Has anyone had a similar fault, or has anyone managed to get the stand off this screen. Thanks for reading.
EDIT:
Adding some text so people can find this thread via Google easier.
Hazro won't turn on.
Light flashes.
Black screen.
Blank screen.
HZ30w repair.
Fix HZ30w.
Hazro won't power up.
Hazro stuck in sleep mode.
Hazro stuck in hibernate.
EDIT:
Light flashes.
Black screen.
Blank screen.
HZ30w repair.
Fix HZ30w.
