- 15 Feb 2011
- North Yorkshire
Are they any good for gaming?
yes
the 8 bit one is
you would need some nice CPU grunt though
i'm not sure which model you're referring to there but assume you mean the HZ27WC? In our tests, the HZ27WA and HZ27WC performed very similarly in terms of pixel responsiveness, but the HZ27WC certainly had the edge in terms of input lag thanks to it's lack of a scaler. The HZ27WB is the other model which had a low input lag but was not as responsive in practice
