HBA/RAID card
31 Jul 2011
Can anyone recommend a decent RAID card (capable of RAID 0, 1, 6 or 10) that can also be flashed to IT mode so it can be used as a HBA. So i would be able to use the card for a specific use case, they can be flashed back to original firmware i presume?
Must be compatible with ESXi/FreeNas/Unraid/Windows 10
You can flash whatever you like to them. Pretty much all the obvious choices lost support in ESXi 7, what’s your budget and do you want ESXi 7 support?
Do you want new or used?
I didn't want to get an ex enterprise card and went for one based round LSI SAS 2308 - was about £100 for a new Silverstone ECS04 and was easy to flash to IT mode
There's probably better value options out there though
