HCI Memory test advice
16 May 2007
Testing memory with hci memory test, it looks like you need to run one per CPU thread.
For my Ryzen 1700 8 core / 16 thread I am running 16 mem tests of 1750mb at the same time. It has passed 150% and is still running with no errors so far, is that the right number to run & the right mb setting ?
Also what is the lowest % to give a useful test ?
Thanks.
TBH i think that HCI test is very clumsy and unintuitive to use. Memtest64 is a much better solution for testing in Windows, you just choose maximum mem (which it is at by default anyway) and press Begin Test. The prog then pages out everything to the pagefile and uses all the memory that's left. You just leave it running.
Around 20 mins as an initial guide is suggested by hci. I run for around 1000% for customers. After this maybe just use your pc to see if it's truly stable.
Run both, I've heard cases of HCI not showing but Memtest86 failing, I guess it's like how I ran P64 for 4 hours and it was "stable" yet IBT crashed after 10 minutes.
Memtest86 is run from a usb stick booted from the bios, Memtest64 is run from within Windows. As it happens, none of them is foolproof and never have been. The problem with running any from within Windows is knowing exactly how much ram is available to test and how much of the OS can be moved to the Pagefile.
That's why i think Memtest86 run from a bootable USB stick is more likely to give an accurate result. It uses much more ram than anything run from within Windows and does the job within 13 hours with 32GB of ram.
I suggested Memtest64 though because it takes all the guesswork out of how much ram is free and how much ram is dumped onto the pagefile.
That is why I run Memtest86 and HCI, it tests it in different environments, sure nothing is fall proof but it helps.
If you go through all the patterns Memtest86 should be accurate in detecting faults - it does complete coverage of the RAM minus a tiny amount used by the system and the only variable really is if its run long enough to detect errors that only occur once the system is warmed up.
Someone made a tool on OCN that helps with assigning threads/amounts. Memtest Launcher Pro. Memtest64 is not anywhere near as stringent as HCI or Google Stress App test ran through BASH terminal.
http://www.overclock.net/t/1628751/...memory-stability-thread/1000_40#post_26419580
There is a new tool that is community driven that is proving to be worth trying out, too. I've found it to be far quicker at catching memory errors than both of the above thus far.
https://www.karhusoftware.com/ramtest/
