HD 3870 Crysis
10 Nov 2007
Anyone have this card and can let me know how it runs
im a bit baffled cause my brother can run his crysis on medium settings
with a pentium d 2.8 dual core 1 gig of ram and a 8600 gt
whereas im also on medium with q6600 2gb 1066mhz ram and a hd 3870
shouldnt mine be a lot better :/
we both have 15 inch monitors @ 1024 - 768
mine is even an old crt :/
could it have anything to do with crysis being a the way its meant to be played game
ive heard about some crysis hotfix for something aswell whats that
It's not that. You should be running it in high or even very high settings at that resolution with the specs your machine has. What operating systems are you both using and what power supply do you have?
P.S. You really do need a much better monitor to do that PC any sort of justice. :p
yea i know my monitor is pants im waiting for payday to get one of the 22" samsung lcds :)
as far as im aware i have the latest drivers so im baffled :/
im downloading the benchmark now
i did let crysis choose for me but i had a go on high yday and to me and it wasn't playable
when i run ati overdrive it says my gpu clock is running at 300 mhz :/
is that the problem or is that a gpu version of speedstep
So....are you using the Catalyst control center?
Try re-isntalling the drivers again, and then look at the overdrive tab...See what the requested field says.
