HD 5770 Crossfire - Showing 0% load on second GPU?
5 Apr 2010
Hi folks.
Just yesterday did my first serious (serious for me is £500+ lol) self build. Part of the excitement of building the new machine was to run 2 GPU's in Crossfire. When I run 2 instances of GPU-Z, the second GPU is showing 0% load. Can't figure this one out, any suggestions would be much appreciated.
Setup:
Intel i7 930 2.80GHz @ 4.00GHz
Asus P6T X58 DDR3 Mobo
6GB XMS3 DDR3 Ram
Asus ATI Radeon HD 5770 CuCore 1024MB x 2 Crossfired
OCZ ModXStream Pro 700w SLI Cert modular PSU
Antec 300 case - running with 3 fans on low
Running on Win 7 64-Bit
2 monitors both plugged into same card (didn't work using 1 monitor/card)
1st monitor 1920x1080
2nd monitor 1024x768
GPU-z Readings:
Core Clock - 850.0 MHz / 850.0 MHz
Memory Clock - 1200.0 MHz / 1200.0 MHz
Temperature - 55.0C / 26.0C
Fan - 30% / 30%
Load - 98% / 0%
Temp #1 - 53C / 26C
Temp #2 - 59C / 23C
Temp #3 - 57C / 25C
VDDC Current % OCP - 30% / 9%
VDDC - 1.0000V / 1.0000V
Currently just running a game called Aion with all settings to Max and AA at x8 in a heavily populated area. Maybe there is something else i could run that will test it better?
Aha!! Yes, I was using Windowed fullscreen. I had no idea that would prevent it from working. Just switched to fullscreen and BAM! both GPU's are loaded fairly equally. Thanks very much for pointing this out to me, you guys are awesome :)
I know this might sound stupid but do you have the crossfire bridge installed on the cards and if so double check it's on both cards firm.
