HD 5870 buzzing?
26 Jan 2010
ESSEX
My HD 5870 has been buzzing for several months now, turn your volume up and watch this vid, the solution i have at the moment is not exactly a good one.
Wow just seen your video.... Okay looking at that video and that top fan grill it's dust in the fans... You want to get that pc cleaned out and remove all dust from fans, grills and heatsinks. Well you now have a weekend job ;).. Get some cans of compressed air and a paint brush to clean the fans and grills and use a vac with a small attachment to suck up the dust in the case.. Maybe worth you buying some fan dust filters too.
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=57&subid=795
http://www.overclockers.co.uk/showproduct.php?prodid=KB-004-OP&groupid=702&catid=1568&subcat=
I would expect this to be something related to the fan. Try taking the side panel off your case while your PC is on at the desktop and put your finger in the center of the gpu fan to slow or stop it for 1-2 seconds and see if the noise stops. If so then you know what the problem is and if its still under warranty, replacement time :)
Needs cleaning i'm sure, after seeing all that dust on the fan grills of that pc .... also after cleaning just make sure to push in the centre of the fan with a little pressure to see if it clicks back in place.. Them fans on the 5870's reference are known to come loose sometimes and applying some pressure on them makes them click back in place.
All they will do on that card for RMA is clean it and click the fan back in if it's loose.. Try what I said 1st if it still clicks and cleaning does not reduce the sound RMA it.. but honestly think you should spend some time cleaning it and maybe a dab of WD-40 on the fan bearing or some machine oil.
My corsair memory cooler was noisy from day one and all I did was spray a little WD-40 in the fans and they have never made a noise since and this is atleast 18 months after doing that... Just make sure if you use any oil to not over do it and make sure to clean any extra oil.
+1
well it's not dust, because that little bit of dust you saw was just abit of buildup outside, i do clean inside every so often. It is defo the graphics card because i held the fan, it wont click back in place as i have tried really firmly, is this a defo RMA fellas?
It could be something simple like a wire resting on a fan or the side of the case. With fan vibration the lead can resonate and create a buzzing sound. It happens to me sometimes and bashing the case seems to temporarily solve it. Taping your leads down could fix it.
I have the same problem with my Asus reference 5870. When the PC is cold and is first booted the fan will make a horrible grinding noise like a lawn mower but will eventually quiet down after about 5 minutes.
This has been happening for several weeks and today I emailed OCUK and they asked me to RMA it for a replacement. The actual card works fine and it's just the fan causing a problem. I see that only the XFX version is in stock and am worried that I will receive one of those as a replacement which isn't really a direct replacement as it doesn't have the metal backplate and doesn't overclock so well not being the reference design. (Read that in the reviews) and has a years less warranty.
If it's true that OCUK will first try some oil and push the fan back on then that's going to be a waste of time me packing it up and paying postage for something I could probably do. I was just thinking it's less than a year old and I shouldn't need to fix it.
Not sure what to do now and I wouldn't be happy receiving the XFX model.
Exactly the same as me, mine aint very old well within the warranty, it starts buzzing when it's cold and after 5 minutes goes away. But it comes back after awhile, really really annoying, let me know how you get on, i personally dont wanna take it apart and fk with the oil.
I took the side of my case off today and checked for dust. All was clean so applied a little pressure to the fan. So far all is good but it has also been quiet in the past and then come back a few days later.
This is what makes a RMA worrying. It could be tested and found not faulty and I will be charged £10 plus p+p for it's return. The problem could come back again and we could just be going around in circles.
The RMA ticket has a 28 day expiry so I have a little time to decide what to do.
I just took my case off, checked dust/wiring/fan/everything i could see, and i'm 100% certain, after poking the fan to a stand still, it's the fan.
it just comes abit loose and makes a high pitch buzzing noise, the actual graphics card is perfect not got any issues, but i guess there is no option but to RMA it, as this noise it louder then all my fans.
