- 4 Nov 2009
- UK
A £1650 build!
I've debated endlessly between an i5 and an i7, and several other parts, however I feel adamant I'm close. I read a thread somebody posted in the Gfx card section about what CPU's complement the 5870/5870 xfire and I feel that there is no point in me wasting £140 or so for a rig which wont be used for encoding... so here it is.. Version 50.595X
The I5 will overclocked to 4.00ghz or around that, and will be my first time overclocking. Will take it slow, and for that reason I also decided to add a replacement apache fan for the h50 because apparantly that's worth sometimes 1-3 celcius.
However how does this look? Is there anything that is out of place or are there better alternatives that would suit this budget better that would allow me to keep the 5970 in there? Rig will be used for Gaming, MS Office, Music, general browsing
Any suggestions appreciated.
- Sapphire ATI Radeon HD 5970 OC 2048MB GDDR5 PCI-Express Graphics Card
- Dell ST2410 24" Widescreen LCD Monitor
- Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - OEM
- Coolermaster HAF 932 Case - Black
- Gigabyte GA-P55-UD3R Intel P55 (Socket 1156) DDR3 Motherboard
- Corsair TX 750W ATX SLI Compliant Power Supply (CMPSU-750TXUK)
- Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
- Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3)
- Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ)
- Saitek Eclipse 2 Illuminated Keyboard - Blue/Red/Purple
- Logitech MX518 Gaming-Grade Optical Mouse (910-000616)
- Sony Optiarc AD-5240S 24x DVD±RW SATA ReWriter (Black) - OEM
- Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM
