- 27 Mar 2014
Just put a second XFX HD7770 in my rig last night and ended up with all sorts of issues main one being windows restarting when you click pretty much anything. I get blue screen with a ton of text that flies past so fast I can't read it then windows reboots asks if I want to restart windows normally. When windows loads back up it says it experienced an unexpected shutdown do you want to check for a fix click ok and nothing really happens and window closes to desktop then rinse and repeat. Seems to run fine with 1 card disconnected. Any help would be great never set up crossfire before so might be missing something obvious. set up is:
MSI Z77A-GD65
I5 3570k at stock speeds
8gb (2x4gb) Corsair vengeance 1600mhz
2x XFX HD7770 double dissipation models
cx600m psu
60gb kingston SSD
320gb seagate HDD
Case is all nice and neat wiring wise and should have decent airflow with 2 intake fans at front, 1 blowing on the gpus and and exhaust at the rear.
Just hoping I haven't underestimated the power needed I did a calculator and it came out at about 480w iirc so thought it would be fine...
MSI Z77A-GD65
cx600m psu
60gb kingston SSD
320gb seagate HDD
