HD 7850
17 Nov 2011
I've installed the latest version of Catalyst Software Suite 12.8, when I rebooted the computer, it goes into Windows and only display the wallpaper with no taskbar or icons
Do you have two displays plugged in? Press Win+P and select projector or computer only. Sounds like the desktop is being extended between the two displays.
Open task Manager (Ctrl+Alt+Del) and go to Processes and see if Explorer.exe is running or not, either way i would close the process and restart it by going to Applications in Task Manager - Then New Task - Type: Explorer.exe and hit Enter.
Its a short fix.
Edit: I would try the above first to rule that out ;)
