- 1 Jan 2009
- Northampton
I just built from scratch a new computer with a HD 7970 Graphics Card. on a 3 monitor setup
I have installed the latest drivers and adjusted the resolution to what each of the monitors support.
1920 x 1080
but I have a big black 1 inch thick border around the screen(s)
its like its reduced the size of the desktop by 20%
If I plug the monitors in to the onboard intel graphics they display fine
I can not find any problems in the monitor setup options and all looks ok in the ATI Control Panel.
Also do I need a active adapter to run Eyefinity from this card?
Connections are
Screen 1 HDMI
Screen 2 HDMI - DVI
Screen 3 HDMI - DVi
Many thanks
1920 x 1080
.I can not find any problems in the monitor setup options and all looks ok in the ATI Control Panel.
Connections are
Screen 1 HDMI
Screen 2 HDMI - DVI
Screen 3 HDMI - DVi
Many thanks
