philio16 said:Why not DV? It's fine for HD content if I remember reading correctly....(please correct me if I am wrong...)
Energize said:I was told that because dv is on tape, that you would have to go trough the whole tape of video to transfer it to pc instead of just ripping it in a matter of mins from a dvd or memory stick. I was also told that they only have a capacity of one hour.
Dangerous said:You still will have too with HD camera as well and yep 63mins or so![]()
Energize said:Surely they sell hd camera with hard drives? Theres plenty of normal camera that use sd cards.
Energize said:Why would space matter when you can transfer the data quickly to the pc with firewire and then just overwrite it? If they use mpeg 2/4 compression it would have much more capacity than dv would.
Energize said:If you used mpeg 2 compression at 20mbits which is what hd-dvd uses iirc, thats approx 120mb per min which is about 7.2gb per hour. With mpeg 4 compression 5 mbits looks almost perfect. hd-dvds only have a capcity of 30gb yet they can fit 2 hours of 1080p on them.
Dangerous said:When I capture I want to capture in full res then down size it at editing if needed.
Energize said:It would be captured in full res. Why wouldnt it?
Dangerous said:P and I are different
Energize said:Come to think of it doesnt hdv use mpeg-2 encoding? So surely youd still have the same problem.
Dangerous said:What you mean? I shoot in 1080i using HDV tapes then edit format in Premiere?
For PC use I use P format and for telly I use 1080i
Energize said:I thought you were talking about the P and I frames used in mpeg encoding.
So Now I go back to asking why wouldnt data on a hard drive encoded in mpeg 2/4 be recorded in full res?
Dangerous said:If you start to record in P you are throwing about 50% of your frame rate.
Hard drive HD cameras are pointless unless you only want to record 2-3 hours then return home. Me on the other hand record 5+ hours of footage on HDV tapes means I dont have to return to PC and wait for it to download.
If you are recording in 1080p you capture in 24/25fps (PAL) or 30fps (NTSC) 1080i is double that![]()
