HD Disconnects
27 Oct 2009
Nottingham
Hey
Tonight my External Hard Drive has started disconnecting randomly whenever my iPod is connected along with it. I can use it on its own, but it only happens when I introduce the iPod.
I think its something to do with the power to the USB's following some research, but i cant find a decent solution.
Help, Thanks!
Hey people, ive updates all everything and the problem still occurs only now the hard drive disconnects while plugged in on its own.
Its a USB powered samsung s2 500gb drive.
any idea? :S Cheers
Does the drive spin down as if it's being powered down? You could try disabling
USB selective suspend in advanced power options for your power plan.
control panel-system and sec - power - change plan settings -advanced
Potentially uses up battery faster on a laptop if you do that btw.
C = 128GB SSD
F = External Drive
Q = Not sure, but is called m4-ct128m4ssd2 ata device [which is the driver for my SSD]
Help pls!
