HD-DVD 360 Help
Don
23 Oct 2005
North Yorkshire
Hey, I've plugged my HD player in but now everytime I switch my 360 on I have to use the media remote to do anything! My controllers aren't recognsied, the lights are just going round the globe constantly. Tried reconnecting them etc but it only recognises the remote...
Hope I dont have to keep unplugging the HD drive as that would be GAY!
Any ideas? The manual says nothing in regards to this.
You could try re-syncing the controller with the xbox.
You know when you press the little button on the front of your 360 and then the small button on the back of your controller.
Had to re-do mine after the recent software update, but glad it didn't die like other peoples have.
Hope this helps.
