HD instead of DVDR's or DL's
16 Feb 2007
Silly question here peeps, but I am curious how "safe" it is to store stuff on your harddrive - unplug it once its full and store it somewhere. A year later or so, u can go back, plug it in and find your stuff all intact.
What I'm asking basically, is the harddrive reliable enough so that u can use it to store your stuff while out of the computer - sitting on a shelf. It would mean less time burning dvds and making coasters, and the prices are dropping so its slowing becoming a vialble alternative to burning.
What are your thoughts?
Would say as long as its stored where mechanical damage is prevented such as a safe it'll be wayyy safer. Could put it in a USB caddy etc.. for easy connection/disconnection when needed.
i've been using my external 400gb lacie like this for ages.
When i want to transfer some stuff to it all i do is turn it on, send the files over and then switch it off.
2yrs on and no problems :P
Yeah im looking at doing this.
Just getting an external drive (them WD mybook ones look ok) fill it up and store it somewhere.
Probably under my bed. :p
Then every now and then update it.
Thanks for your help peeps, I think I might start looking into doing this because dvdr and DL are really .... crappy, just not doing the trick. Takes ages to burn, only to find that u got a coaster and even then u got tons of dvds everywhere. might be sensible to just store what you need on a harddrive then unplug and buy a new one.
magnetic media isnt the best idea for long term storage and archival, i would look at either blu ray or hd dvd as the prices of those come down it would be more viable and up to 50 gb per disc ! I also read a report recently from google's tec deptmartment on disc failure, and it would appear that contary to popular belief, the best performing and longest lasting hdd's in there server arrays , are the ones in constant use, the lesser active drives have the higher failure rates, also drives lasted longer in warmer conditions and preferd to be powerd but inactive as opposed to be switched off.....
Intresting, certainly blows a few preconceptions out the window.
Never trust keeping your most important data on a single disc or harddrive..Always backup your most important data to two harddrives or DVD-r/CD-R etc
here is part of the report from the bbc news site
Last Updated: Monday, 19 February 2007, 15:28 GMT
E-mail this to a friend Printable version
Hard disk test 'surprises' Google
Hard disks are getting smaller with greater storage
The impact of heavy use and high temperatures on hard disk drive failure may be overstated, says a report by three Google engineers.
The report examined 100,000 commercial hard drives, ranging from 80GB to 400GB in capacity, used at Google since 2001.
The firm uses "off-the-shelf" drives to store cached web pages and services.
"Our data indicate a much weaker correlation between utilisation levels and failures than previous work has suggested," the authors noted.
A wide variety of manufacturers and models were included in the report, but a breakdown was not provided.
Widely-held belief
There is a widely held belief that hard disks which are subject to heavy use are more likely to fail than those used intermittently. It was also thought that hard drives preferred cool temperatures to hotter environments.
The authors wrote: "We expected to notice a very strong and consistent correlation between high utilisation and higher failure rates.
"However our results appear to paint a more complex picture. First, only very young and very old age groups appear to show the expected behaviour."
A hard disk was described as having "failed" if it needed to be replaced.
The report was compiled by Eduardo Pinheiro, Wolf-Dietrich Weber and Luiz Andre Barroso, and was presented to a storage conference in California last week.
In the report the authors said Google had developed an infrastructure which collected "vital information" about all of the firm's systems every few minutes.
'Essentially forever'
The firm then stores that information "essentially forever".
Google employs its own file system to organise the storage of data, using inexpensive commercially available hard drives rather than bespoke systems.
Lower temperatures are associated with higher failure rates
Google report
Hard drives less than three years old and used a lot are less likely to fail than similarly aged hard drives that are used infrequently, according to the report.
"One possible explanation for this behaviour is the survival of the fittest theory," said the authors, speculating that drives which failed early on in their lifetime had been removed from the overall sample leaving only the older, more robust units.
The report said that there was a clear trend showing "that lower temperatures are associated with higher failure rates".
"Only at very high temperatures is there a slight reversal of this trend."
But hard drives which are three years old and older were more likely to suffer a failure when used in warmer environments.
"This is a surprising result, which could indicate that data centre or server designers have more freedom than previously thought when setting operating temperatures for equipment containing disk drives," said the authors.
The report also looked at the impact of scan errors - problems found on the surface of a disc - on hard drive failure.
"We find that the group of drives with scan errors are 10 times more likely to fail than the group with no errors," said the authors.
They added: "After the first scan error, drives are 39 times more likely to fail within 60 days than drives without scan errors."
