HD LED Light Antec 900??
15 Oct 2007
Bedfordshire, UK.
Should there be a HD LED light on the Antec 900 Gaming Case, i quite sure i plugged a cable labled HD LED into my mobo, but cant see no HD led on the outside of the case??
I was surprised Antec did not include a power led there too, seems a bit tight of them!
The Hdd led lights up the ceiling though when it flashes :)
Indeed - not in need of a power LED. I do have couple other niggles with the case though;
The leads that you connect to your mobo for the HDD,RS,PWR etc arent long enough - if you're trying to tidy the cables up a bit there's nowt you can do but run them in a straight line to your mobo.
The reset button is too small - have to dig in with my index finger or use the pinky.
Other than that, I like it. :)
would have been nice it they mounted a switch on the outside of the case that you could control the fan speed with
This seems to be turning into a general plus/minus fest...
As I was setting up my Antec 900, I too was worried about the lack of a power LED....no longer. :)
I found the cables from the top USB/Firewire/sound ports were long enough, but because of the position of the PSU, I did/do have a problem with the routing of the ATX power connector (i.e. straight line from PSU to the ATX power socket on the MB :)
Cable routing in general seems to be quite problematic, but I've seen a good example on these boards of a mod to make that easier.
Also concur on the fan-speed switching. Is a pain to have to remove the case cover to change the fan speed.
The little area with the rubber mat on top of the case is just right for change/iPod/case screws/usb sticks etc. though the temptation to put a can of drink down on it... and so close to the massive opening behind it is a little much :D
