I've just built a new PC with the intention of using it as a media centre. It's an Intel Dual Core E2180 with 2 GB RAM so should have plenty of power to run 720p videos. I'm running on 64bit Vista.
I'm using the CCCP codec pack and Media Player Classic, but I'm having problems with frames being dropped when playing HD movies (be they .wmv, .mkv, the format doesn't seem to matter). This is causing noticeable jerking on playback.
I'm assuming the hardware has enough power to play 720p files, so I'm thinking its either an issue with the codecs or Vista. Does anyone have any recommendations on tweaking the codec settings, or other codecs and players I could use? Or should I try putting XP on it as I've heard that 64 bit vista isn't great for video playback?
