HD question.
20 Nov 2006
Just a quick one.
Ive just bought a nice new LG monitor which is capable of displaying full HD. I was just wondering, would i get better pic quality via HDMI or the DVI-D plugs ? or isnt there any difference ?
Thanks.
thanks guys, will save the hdmi slot for a console then !
EDIT:
PS. how can i tell if im running HD properly. Im fairly new to HD on PC's !?
If you've got windows running a res >= 1920x1080 then you can run HD video :) So look in the display properties.
Most 24" monitors run at 1920x1200, but you do have the new breed that run at 1920x1080.
Ah ok thanks for that.
And finally, whats the best media player for playback of HD video, are there any special codecs i have to install etc ?
