HD2600Xt Gives me a Blank Screen!
30 Jun 2005
Hi all,
I just bought a sapphire hd2600xt 512MB ddr3 Pci to replace (gpu per gpu) my old x800xl.
Problem is my pc gets to the window xp loading then all i get is a blank screen. All fans are spinning and the HDD light is blinking. :confused:
I've read it could be a PSU power or Mobo compatibility. ?
I took it off and just put my old car back which loaded just fine.
I havent updated to the latest drivers yet but i still want to know if anybody else has had this problem and what might be the solution.
Thanks!
Alex
