- 4 Jan 2008
Hi All,
I need a little advice.
I am currently upgrading my 250w PSU to an enermax 620w PSU and my graphics card from an X1600SE to either one of the above.
Budget is not really an issue, however I will most likey buy a new PC at some point next year (as at the moment in order to increase my ram I have to upgrade my Mobo and install Vista which will be a few hundred quid and so its better to just buy a new PC)
I am running XP and play games - not massively, but when I do I like a good, smooth, decent FPS experience.
I am unsure whether to get the x2600Xt or the X1950pro
The X2600xt looks better on paper with GRR3, 830mhz and 1860mhz
The X1950pro also has GRR3, but with 580mhz and 1400mhz
There is only a few quid (literally about a tenner) between them.
Both are 512mb memory.
Which would you guys suggest.
I am running an e6400 core 2 duo, with 2gb ram and one PCIe port 1.0.
Any suggestions welcome.
