HD555s for 360
16 Apr 2007
UK
Hey all,
I currently have my 360 connected (audio wise) to my PC speakers (Aego Ms) through RCA (Red/White).
However, I have the Sennheiser HD555s and want to be able to use them on the xbox 360.
The Sennheisers have an output of 6.3mm jack (with an adapter to reduce it to 3.5mm)
How would I go about this?
Thanks,
Marky
2x RCA Phono Female to 1x 3.5mm Male + 3.5mm female connector
or
"2x RCA Phono Male to 1x 3.5mm Female"
Can easily be found, have a quick google and something should come up.
I really wouldn't plug the headphones direct in to the 360 - you'd have no volume control whatsoever.
Best bet is either get a headphone amp (I'm using a DIY amp between my 360 and 555s) or use your PC sound card amp, line in/headphone out. Either that, or even easier, do your speakers have a headphone/output port anywhere?
I bought a project headbox MII. works great with my hd555's. I actually wear the xbox chat headset underneith so I have control of both volume.
