HD5770 Temp/Fan Query/Issue
Thanks very much - will find some time over the weekend and attempt to get some better speeds from the 5770.
Do you use fans on the side of the case?
I haven't installed any yet (got the case about a week ago) and I don't have any 3 pin power splitters, but I'm happy with the temperatures I'm getting so they are probably not necessary. How about you?
Not using any on the side at the moment just the push pull setup on the H50 and the one located near the HDD bay on the case.
GPU sat at 36 degrees this morning (cold up north)
That's more like it! I know that if you use catalyst 10.6 the idle clocks don't clock down as far, so the idle temperature rises, that's why I'm sticking with 10.4
