HD5850 Extreme problems
4 Apr 2011
Hi,
Purchased the Hd5850 extreme and had a few problems yesterday with install.
I have a Core i3 540, ASRock P55, CM 700W Gold, 8GB corsair RAM and running Win 7 64 bit.
So yesterday i remove the Hd5770 i had and put in the Hd5850, it kept crashing loading games so i uninstalled all the old drivers and CCC and managed to play Crysis 2 and CoH fine.
Come home from work today and it won't load anything again, its fine in the menus of games but crashes as soon as the actual game loads.
Have tried uninstalling everything ATI/AMD related and starting again but same problems.
Any help?
Thanks
Emma
I just had a problem similar to this, and what i did was take my 5850 out the pci-e slot
and make sure theres no dust in there, and then make sure when u put it back in it goes
in the pci-e properly by just adding a little more pressure.
do you get a triangle icon in tray saying AMDKMDAP has stop responding etc.
I though i had fixed mine, but now ive tried everthing i can think of to get it to
work. So now im returning it so i put back in my 8800 gts 512 removed ati drivers
put nvidia drivers back on and bam everthings working again so its got to be the
card not my computer:/
Had similar problems, But mine loads into game fine. For example waiting for a map to load in black ops and it crashes for 30seconds - 60seconds
