- 3 Jan 2013
How do,
I'm running with a single 6770 at the moment and I've been offered another 6770 from a friend at a bargain £20.
I'm planning on getting it and installing it alongside the existing as a cheap upgrade. Problem is I've never (knowingly) worked on an overclocked system so I haven't a clue if I'm going to screw up the systems stability by doing this.
Can anyone advise as to whether I'm likely to encounter any problems with the CPU overclock - I'm assuming I won't. Also will the 650w PSU be ok with the extra drain?
Specs:
ASUS Sabertooth 990FX board
650w PSU
AMD FX 6100 @ 4.03Ghz
8GB RAM
XFX HD 6770 1GB
Standard optical drive
Single 1TB Seagate HDD
Any assistance would be appreciated.
Specs:
650w PSU
8GB RAM
XFX HD 6770 1GB
