So I've discovered that the 6850 only displays analogue displays on one DVI port, so I've been trying to find a way to get both my VGA monitors working and I think I've found it, and I'm looking to find out if it will work.
I've found this:
http://www.amazon.co.uk/gp/product/B001RPCZL4/ref=s9_simh_gw_p147_d0_g147_i1?pf_rd_m=A3P5ROKL5A1OLE
Which, theoretically, would let me connect one display to the DVI port that allows analogue conversion, and use that DisplayPort > VGA converter to display the second monitor.
Would this work? Would I be able to extend a single display over both monitors even though they're coming from 2 different ports? What would the maximum res for each screen be?
I've found this:
