- 9 Feb 2009
I ordered a VTX3D HD 7950 from here a couple of days ago and have been having loads of problems with the drivers.
at first when i installed it worked fine for the first day or two, however i didn't really use it for gaming or anything stressful. then last night after about a hour and a half of gaming the screen froze (everything else was still working fine, sound etc). i was forced to re-set the PC, and since then the GFX drivers stop responding every 30 seconds when gaming (screen goes blank, then windows "recovers" the drivers).
i have tried all the common things, updates off the AMD website, re-seating the card, double checking the power supply inputs, installing (plus running drivers sweeper) and re-installing the drivers.
Anyone got any ideas or had similar problems? my google searching hasn't turned up much information about it, in fact most people say the AMD drivers are really stable.
System is a Corsair 650TX (around 3 years old now), 1x VTX3D HD 7950, Asus P5Q Pro Mobo, Intel Core2Duo E8400 (Wolfdale chip running at stock speed atm) 1x solid state hd, 3x normal hdd. Im running Windows 8 CP, (i have tried both the Windows 8 drivers and the Windows 7 drivers from AMD).
Thanks,
Thanks,
