So yeah, another AMD problem. I think in my case it is going to be my 100th issue with AMD cards. There should be a section called "AMD Problems" where everyone can post their issues with AMD, and so I can see how bad AMD actually suck, and not just for me.
Issues, issues and more issues. Does it ever end?
Any chance you guys could tell me, does AMD drivers have self-awareness, are they intelligent and mean? From my experience I say that they like to toy with us, users.
Ok let me explain my 1210821892 problem with AMD, what happened.
Yesterday I have build a new system for my friend and had to use one of my three monitors so I could install system on it and everything else. I have used monitor that connects via DVI (other two are DP connected), everything was fine, till I plugged it back to my system.
So what is the issue? I won't ask you to guess because of amount of problems you get with AMD, it is not really possible to answer the question.
OK! The middle screen started to blink/flicker. Every few seconds/minutes, screen blinks for 0.5sec, goes black and then back. Sometimes it just keeps repeating, sometimes it takes 2-3 minutes for it to blink/flick. It is seriously annoying, and when I change DP ports on the card, it totally freaks out. It makes different lines all over the screen and ****, flickers like crazy.
Driver re installation didn't help.
What could be the issue, faulty cable, **** AMD cards, drivers that worked fine for few weeks?
Kill me.
Please fully star out all swear words -w3bbo
Kill me.
