Hi
I'm looking to build a PC that I can use for a bit of gaming, but mainly use for media purposes. Now that 4K has settled down, I'd like a bit of advice of the GPU that either I should get now or wait for potentially a future release. I'd be looking to spend no more than £300
As far as I'm aware there are only 3 cards with HDCP certification
GTX 960
GTX Titan X
GTX 980 Ti
With my budget constraints, the last two are a no go.
Ideally I'd go for a GTX 970 but that isn't HDCP 2.2 compatible
Are you aware of any cards soon to be released that would be a step up from the GTX 960 and are HDCP 2.2 compatible?
Many thanks
Ron
GTX 960
GTX Titan X
GTX 980 Ti
Many thanks
Ron
