HDD build issue
  • Thread starter Thread starter Deleted member 157462
  • Start date Start date
I'm currently trying to fit a
http://www.overclockers.co.uk/showproduct.php?prodid=HD-257-SE&groupid=701&catid=14&subcat=1279
into a
http://www.overclockers.co.uk/showproduct.php?prodid=CA-066-XG
and i simply cannot find where the HDD is meant to go, and no one I've asked has been able to work it out either
help please?
here is a side view picture
Bottom right is for 3.5" hard drives, the cage above is 2.5" for smaller HDD's or SSD's & the top right is for CD/DVD drives.
I imagine the case would have come with 'rail/slide on' brackets for putting on the HDD's and then sliding them into the case area.
check the packaging that the case came in, there maybe adaptors to fit to the HDD's before fitting to the cage?
From the Info on the sale page:
Drive Bays: 5.25" External x 3 (tool-free retainers) / 3.5" Internal x 4 (tool-free retainers) / 2.5" Internal x 4 (3 tool-free retainers, 1 mount with screws)
thank you all very much for the help, i found the adapters and no mention of them in the case guide
