- 31 May 2006
- West London
Hi all
With the rise in temps and my wife's hayfever the house's ambient temps are nudging 30 so my passive
cooled pc is have a few issues.
The water cooling loop is fine (cpu and NB) as is the 8500gt with it's oversided passive cooler. But my
hard drives are sitting at 50-51
I've a 36mb Raptor and a 300mb Seagate both hang in a bungee cradle an have no active cooling
(either direct or via case fans) The one fan in my setup (900rmp in psu) vents to and from outside
the case.
I've droped the OC but no surprise it makes no differance as that all water cooled.
I can think of four solutions:
1) remove side of case (increase air flow)
2) add fan under HHD - this is part of the silverstone CW01 design (could 7v it)
3) add larger Heatsinks to HDD - improve heat dispersal (aka HHD caddy)
4) rotate PSU/block case inlet - so air its pulled through case and out psu.*
Your thoughts and ideas please.
*the case that the psu in a standard atx orintation but at bottom of the case (when wall mounted) so air is pulled up into the psu and out the back
the case.
