Hi Guys,
I built my new PC today (spec below) and all seems to work fine, apart from one strange issue.
If I plug my HDD indicator light plug into the correct header on the mobo, my system will boot and restart and keep looping. I can hit DEL and go to the BIOS and it shows the top/title of the BIOS but no system info below, sits there for half a second then reboots again. Upon booting the HDD indicator light on my case does light up, so its sending something.
I've tried spinning the HDD plug around so the +/- swap sides but then it boots fine but no HDD activity so that is clearly the wrong way round.
Spec:
EVGA GeForce GTX 680 Superclocked 2048MB
Intel Core i5-3570K 3.40GHz (Ivybridge)
Seasonic M12II 650W '80 Plus Bronze' Modular Power Supply
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
BitFenix Shinobi USB3.0 Gaming Case
Samsung Green (MV-3V4G3DUS) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit
Samsung SH-224BBBEBE 24x DVD±RW SATA ReWriter
Any ideas, I've never experienced this before.
Any help appreciated.
ta
Spec:
ta
