HDD Partitioning
Permabanned
17 Jan 2006
Haskins
Can you do this to a slave SATA drive within Windows. If not, could you pretend to re-install Windows booting to setup screen and partition it there then just cancel the install!?
Thanks
Thanks
Yes you can do the pretend reinstall thing but you can also do it the way as said above ^^^^
