HDD SMART software recommendation
Caporegime
28 Oct 2003
Chestershire
My PC is on its very last legs now and randomly shuts down at inopportune moments almost every day. Today it did it during a copy/write process. I did a disk check in Windows 10 using the Command Prompt CHKDSK D: /F and nothing untoward flagged up but sometimes there are problems that aren't detected without doing a /R but that would take more than 24 hours on a 2TB drive.
Is there any free software you can recommend that queries the HDD's SMART interface so you can see if it's detecting bad sectors and whathaveyou?
Thanks.
PC randomly shutting down would rather point to a failing PSU. Seems like you have old hardware and the PSU might be on its last legs. I would recommend Hwinfo for SMART monitoring. Have you checked event viewer for any suspicious events right before the PC shuts down?
Oh yeah, it's got to be a power problem. I'm just wondering whether every time it crashes if data is getting corrupted on my data drive. As I say, yesterday it went right in the middle of saving.
There's nothing in the event log about it.
