Hdd to Disc
ajm
ajm
13 Apr 2004
I'm not sure if this should be posted here or somewhere else.Please move if nescesary.
I have a Dvd recorder with built in hdd, if i record to hdd then copy that recording to Dvd-rw how can i make it readable on another dvd player.
Its possible to finalise rw's. Without knowing what model recorder you have, your best bet is to have a flick through the instruction manual to find out how to finalise discs :)
Thanks Kfa i will take a look in the manual.
Model is Chili DVR-9200HX.
Just finalised the disc on the recorder and when i put it on pc the disc shows up with nothing on it but says it is not empty. :confused: :confused:
I have now managed to be able to view the files on the pc but not on other dvd players.
Any suggestions?
Thanks for the reply Jez but i know that the dvd player that i am trying it on can read -rw and +rw because i have tried it with other dvd files.
All i can suggest is that you bat off an email to your dvd recorders helpdesk then, or give them a call if they have a tech support line. You cant be the only person with the problem if it really isnt working :)
Ok Jez thasnks again i will try that.I thought it was something simple that i might have missed as my brother has the same problem with his dvd recorder but his is a different brand.
