Having an issue with sata hdd's not showing up on a new build. Drives are an ocz vertex 2e 120gb ssd and a samsung f3 1tb. Theyre not showing up in bios or detected when i go to install windows, (f3 unplugged as it's a storage only drive). But i gave it a quick try, used both the sata 3 and 6gbps connectors, also tried multiple sata cables. Spec below
Intel 3570k
Asus p8 z77 v pro 1155 mobo
8gb corsair vengeance lp
Bios is set to AHCI, blu ray dvd drive is showing up fine. Strangely though, the ssd drive is detected and working as normal when i put it back in my old x58 rig, (posting from it now).
17 920
asus p6t deluxe
12gb kingston hyperx 1600mhz ram.
Intel 3570k
17 920
asus p6t deluxe
