Hello
I’m getting at 1080p 3D TV soon, probably the LG 42LF652V and was wondering whether I should use a HDMI 2.0 cable with it.
I already have a 1.4 HDMI cable, is this good enough or should I upgrade?
It will be plugged into a GTX 960 and used as a PC monitor for movies both 2D and 3D, gaming and if the resolution is good enough and there’s no text ghosting, web browsing.
Thank you.
Thank you.
