- 12 Aug 2010
Hey chaps,
Basically I have access to both, although I don't have a HDMI cable at the moment so I can't test. Now, I can't for the life of me find any tangible information as to which is generally better for gaming/blu-ray 3d on a 1920x1280 resolution monitor.
The sound is not an issue as I have a sperate sound system, but I've heard that HDMI 1.4 has a huge update in terrms of 3d development? Which is something I am leaning towards. I have a DVI cable in now, and it looks great, however I have nothing to compare it to. It seems that DVI is pretty stationary in terms of development? As HDMI has had versions 1.0, 1.1, 1.2, 1.3, and now 1.4.
Would like to know what you guys are using, and what you would use if you had a choice? In addition to some pro's and con's to using HDMI 1.4 as opposed to DVI.
Cheers,
Steve.
Cheers,
Steve.
