My AV setup is ancient and so a full upgrade is needed for the xbox series x and PS5.
Thinking of the LG GX with a Denon AVR-X3600H amp.
I'm really confused about how to make everything play nicely with HDMI 2.1 in the right places, how eARC actually works in practice, and how I can still support DTS audio from the PC?
The LG has 4x HDMI 2.1 ports, however, I am used to plugging devices into the amp, then passing that into the TV via a single HDMI cable. (mostly as my old TV has limited ports)
From reading this is not suggested now? To take advantage of the TV features external devices plug in directly?
Audio is then sent to the amp via eARC - how is this setup, is it automatic, is it set and forget?
It seems that AV amps with multiple HDMI 2.1 ports are not yet available, or will even be available if the preferred route is TV connection rather than amp -> TV?
The other issue is DTS audio. The LG no longer supports it, so if I plug my PC into the LG CX will it pass-through DTS audio to the Denon, is eARC capable of this?
OR
Will I have to use the single HDMI 2.1 in on the Denon for the PC, decode the DTS on the amp then send the picture up to the TV
OR
Do I need to plug the PC into the TV HDMI port and sepertaly output via Optical to the amp?
Reviews for both the LG CX/GX and the newer HDMI 2.1 amps maddeningly gloss over the implementation details for these details only mentioning the official specs!
OR
OR
