HDMI cable not fitting through case into graphics card
Hmm well i managed to get it in, the lead casing had a little ring that i could take off to get it in further. But then i had another problem. When i put the lead in, my Catalyst centre came up with a box about confirming the new connection found, so i thought it had worked, but then i took out the other lead i'd been using so far and the monitor said no cable connected.. so i don't know what's going on there. I know the HDMI cable works because it was taken from the xbox
Try it in the xbox again, make sure that in the process of moving things the cable hasn't died, unlikley but hey you never know!
Have you tried booting up with just the hdmi lead connected? Maybe having both leads connected is confusing it?
And just to confirm you are selecting the HDMI input on the monitor once you plug it in if it doesn't auto switch to it?
Got it sorted thankyou =) a different HDMI lead worked it in and the monitor was being picky about how it picked up the connection. It didn't want the automatic option on, it worked when i changed it to manual
