A cheap one (if it's short) should be fine but be careful of the connectors on them.
HDMI isn't a very good connection, like say DVI which makes a very positive connection.
I've had a load of trouble with a cheap cable that had poor connectors and didn't sit properly in the sockets. It took me ages to work out what the problem was.
HDMI is a digital connection though and you shouldn't have to spend a lot if it's anything up to a couple of metres.
