hdmi cable
From Wikipedia:
Although no maximum length for a HDMI cable is specified, signal attenuation (dependent on the cable's construction quality and conducting materials) limits usable lengths in practice.[58] HDMI 1.3 defines two cable categories: Category 1-certified cables, which have been tested at 74.5 MHz (which would include resolutions such as 720p60 and 1080i60), and Category 2-certified cables, which have been tested at 340 MHz (which would include resolutions such as 1080p60 and 2160p30).[55][59][60] Category 1 HDMI cables are to be marketed as "Standard" and Category 2 HDMI cables as "High Speed".[1] This labeling guideline for HDMI cables went into effect on October 17, 2008.[61][62] Category 1 and 2 cables can either meet the required parameter specifications for interpair skew, far-end crosstalk, attenuation and differential impedance, or they can meet the required nonequalized/equalized eye diagram requirements.[59] A cable of about 5 meters (16 ft.) can be manufactured to Category 1 specifications easily and inexpensively by using 28 AWG (0.081 mm²) conductors.[58] With better quality construction and materials, including 24 AWG (0.205 mm²) conductors, a HDMI cable can reach lengths of up to 15 meters (49 ft.).[58] Many HDMI cables under 5 meters of length that were made before the HDMI 1.3 specification can work as Category 2 cables, but only Category 2-tested cables are guaranteed to work.
So any old cable should do 1080i over 15m but for anything above that you need a Category 2 or "High Speed "cable.
From Wikipedia:
thanks for the help it should be fine then because the tv only has a res of 1366*768 (or somthing like that it is 4 years old :))
